any info on LS1 swap???
im lookin to swap my 305 tpi out for a ls1 or if im lucky ls6. if i were to do this i would have someone do it for me. how much would it run me for labor, and if no one could do it what about the difficulty of doing this?
Re: any info on LS1 swap???
But labor will run you an absolute TON; as in several thousand. But and LS1 in such a finely balanced car as an IROC would run amazing
http://www.thirdgen.org/techbb2/foru...?s=&forumid=20
This will help you out a lot, there's a TON of info about swapping in an LSx motor either yourself, or some shops that have done this. This is something that is on my long term goals list of things to do, though it'd probably be an LS2 by then, punched out to an historic Pontiac displacment, would that be 455?? sounds good to me .
10-31-2016 11:09 AM
Henson071
05-04-2015 12:23 PM
bonniew
Events and Cruise Spots
01-18-2015 01:14 PM
