anybody have used gears??
Re: anybody have used gears??
Originally posted by irocz8957
i was wondering if anybody out there has used gears for a 9bolt i have 277's right now and want like 323 or 342
will not work.
People seem to forget or do not know that you CAN NOT mix 9-Bolt and 10-Bolt parts. They are NOT INTERCHANGEABLE!!!!!
You're going to be limited to either a 3.27 gear like my car has, or a 3.70 for the M-5 305 TPI 9-bolts.
9-bolt stuff is pretty scarce and pricier than the 10 bolt parts, although the 9-bolt is a lot stronger of the two.
Dave
Dave
The 3.70 ratio was only used in the '85 305/T5 cars, 86-89 got a 3.45 ratio. And as far as new gears go....you can buy a complete used 3.27/3.45 posi disc rear for about the same price easy enough. 3.45 rears are hard to find though.....3.70's are even harder. I have the only factory 3.70 9-bolt rear I've ever seen.
I have new 9 bolt gear sets to 4.10 ratios.
I have some used to 3.45 too. I am working on some
used ratios of 3.73 and 4.10 that should be ~ 1/2 the
cost of new gear sets. I hope to have the ring gear spacer
stuff worked out soon too. Just trying to finish the rear support cover first.
All the info is at www.9bolt.com or www.diffsolutions.com
I will be updating the availability and price pages these week.
Miles
Miles
ChrisFrez
03-22-2015 09:12 AM
