Anyone know the rearend width???
All third gens are the same width. Roughly from the end of the axle to the end of the axle is 63" +/- 1/2". That's the surface that the drum/wheel will mount on. Changing that width will require different offset wheels.
Most factory 9" housing are too wide but there are a few models that work well. I used one from a 1970 F100. The only bad thing about it is that both axles were the same length. That put the pinion over to the passenger side 2". A proper car diff will have the pinion in the center and the driver side axle will be shorter than the passenger side.
I installed mine with ladder bars so I didn't have to worry about finding some way to attach the torque arm.
Speeds8erM-1
Classic Engine Tech
08-21-2002 02:06 PM
