anyone using an MSD 6AL?
if so what are your opinions on it? what setup are you using along with it?
I need to get a new cap, coil and rotor for my car like NOW and I was just thinking about upgrading to the MSD 6AL along w/ the rest of the MSD components.
I'm running an HEI distributor w/ MSD Super Conductor wires and and MSD Super HEI Ignition module (I know that will be bypassed w/ the 6AL box) I am hoping to be doing a 383 builup this winter while the car is in storage so should I just upgrade the ignition system now or just do the cap and stuff for now? the setup I am looking at is the kit which has PN 8500 its everything that I need to put it in and get her running well again.
thanks
Jay
black 85 Z28 - waiting on a new paint job, then she'll be real purty
87 Chevy S10 Blazer- 2.8 liters of pure fury
Jay's Website
yahoo im: wildcat856
AIM: Jayman85Z
Homer no function beer well without
check out GMPerformance.org
thanks
Jay
Jay's Website
AIM: Jayman85Z
I use one in both of my cars. the 86 is carbed and has full msd in it. ie. distritor, cap, coil, 6al. def. a good upgrade if you plan on reving higher then stock levels and/or making more power. its a must have for nitrous/superchargers (IMO) plus it has the rev limiter.
chris
1985 Iroc Z, (parting out, email for parts)
1986 Iroc Z, (up and running, but still lots of work to do)
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solid cam .501I .510E, 4gen rear w/3:73posi,girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd :6al, coil, dist., mallory wires. exp high 12's-low 13's
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
chris
thanks guys
yeah Z_Ghost, I asked over on GMP as well.... I figured I would get as many opinions as I could about it
Jay
Jay's Website
AIM: Jayman85Z
Jay
Jay's Website
AIM: Jayman85Z
ttt?
Jay
Jay's Website
AIM: Jayman85Z
Jay
Jay's Website
AIM: Jayman85Z
I have the pro-billet distributor, seperate blaster coil, and the 6AL box, taylor spiro-pro wires, and AC rapidfire plugs. Works great, durable, and was worth the money,(the distributor is machined from a solid piece of aluminum) Makes the powerband alot smoother.
1989 IROC-Z 355 M5
13.0@104
MACC All Camaro Show-
1st Place
3rd Gen Modified
1988 Chevrolet K-5 Blazer
6000 lbs. of a real SUV
2001 Yamaha Raptor
92 mph on radar!
1989 IROC-Z 355 M5
13.0@104
1st Place
3rd Gen Modified
2001 Yamaha Raptor
92 mph on radar!
i have the 6al box with probillet distributor, blaster 3 coil, msd wires, and ac plugs. the setup works really good for me. you have to put the box in a spot where it isnt gonna get hot though. i tried to conceal mine on the firewall and on really hot days or in traffic i will have a miss at constant throttle. gonna buy a small fan for it though. should take care of it. good luck i really recommend going with the stroker.
brandon
79 Z, 357, pro1 heads, victor jr.intake,
prostars, powerglide, 9" ford w/ 4.86 gear, etc...
best pass to date :10.16@132.72mph
91 rs stroked not sprayed
11.86@115 so far........
brandon
I ran everything stock new except for a msd 6al I think it's the only thing that kept my truck running.. wouldn't run without it, that I can say.
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Mods;
ntimad8.cz28.com
Im using the 6al box with a blaster 3 coil and my original external coil distributor, it works great especially when the tachs bouncing around 6500rpm because of the rev limiter... gotta get a new chip
