Auto Trans in an 1988 Trans Am
Re: Auto Trans in an 1988 Trans Am
There is a plastic gear on the tailshaft, which spins another plastic gear on the magnetic pulse generator, which sends the signal electronically to the computer. I believe its 2000 pulses per minute. Firebirds used the electronic speedo starting in 1989, while the Camaro didnt switch until 1990.
If you change your rear end gears, you need to change the plastic speedo gears in the tailshaft. The VSS stays the same.
Thanks. Out of curiosity it's 1989 not 1988 when Pontiac switched to electronically driven speedo or vss? I thought my 88 had a vss not a cable but I could be wrong.
i think you mean pulses per mile
if i rememebr correctly, pontiac switched to a vss/electronic speedo in 1987
camaros kept the mechanical speedometer until 1989
but i could be wrong
Yeah I think you have it would the 1987 Firebirds switching to VSS and I know Camaro's didn't switch till 1990.
Anyway next quick question then. I have a Transmission out of a 1987 Camaro that was already rebuilt and modded before the it was taken out of the Camaro. Can I use this transmission in place of the Transmission in the Trans Am with just swaping the VSS deviece or what else would I need? Thanks.
Whooops! I meant pulses per mile, yes.
I am pretty sure the Firebirds switched to electronic speedo in 1986 as I have a friend with an 86 Trans Am, and his is electronic, while another 85 Trans Am I know is cable.
Camaros definitely switched in 1990.
Yes, the Firebird tranny and Camaro tranny is identical, except for the VSS speedo signal. Use the speedo gears and VSS from the Firebird and you'll be fine.
01-05-2015 07:14 PM
Sarahrope64
11-27-2014 11:17 AM
