Automatic shifter plates
Guest
Posts: n/a
Are they basically the same from from 82-89 and 90-92 (or whatever the year differences are)? Why are the later years discontinued?
By the way, how do you get the shift lefter OFF so that I can get this plate out? Does the little button on top just pop out (along with the spring)?
There were a few different models.
82-83 had a 3spd tranny and there for read P R N D 2 1
84 I think read P R N D 3 2 1
85-87 read P R N @ D 2 1
And then 88-89 was similar but had an indicator in red to tell which gear you were in
90-92 was the same as 88+ only difference was the yellow lettering.
I think thats all of em. Pontiac had some weird ones too. I need a replacement for my iroc, the indicator is busted and sometimes reads N when I am in OD
Hope that helps
Will
Hope that helps
Will
To remove the Auto shift ****, locate the U-shaped clip on the front of the **** (facing the radio) and pull out. It is about the size of a paperclip wire. Then just pull up to remove. All 700R4 Shift Plates are the same except for color changes on the letters & numbers. P R N od D 2 1 , Early 82/83 models did not have the OD on them and were 3 speed.
Guest
Posts: n/a
Sweet thanks.
BTW why the hell did they go to yellow coloring? White looks so much more cleaner. I wonder if the white switches are identical to the yellow ones?
They just wanted something different. I guess they are more visible??? But yeah, if you have a pre 88 car though, its a little different removing the ****. You will need a snap ring tool to take the little clip out and then the **** will slide out. the other dude failed to mention that
Will
Will
The other dude can remove the shift **** without a big old snapring tool and I have 87 with Auto ****. I guess the directions were to hard for you without your tool box.
Nah, its just those of us who can afford tools like to use em, get a life you Saq of Shiiit. If you weren't so godddamn bloated you would realize that everything you said in your post was what I already addressed. You don't have a single friend on this board, everyone knows you're a full of crap pussie who has nothing better to do than post negative shiiit. Sack up get off our nuts dude, quit playin with your **** homeboy
I cannot believe my eyes. This crap is completely unacceptable. This is a well respected, family-oriented message board. Tou two, obviously, are not willing to acknowledge that.
Take this to email and out of the forum.
Steve
Steve
detroitmuscle
07-31-2015 04:21 AM
ducttape1975
07-10-2015 06:29 PM
