Which battery charger should i get
hey guys anyone have suggestion on the best charger to get and whaere to get it from.
these were some of the ones i wqas looking at:
http://www.sears.com/sr/javasr/produ...0&bidsite=null
http://www.sears.com/sr/javasr/produ...O&bidsite=null
those last 2 links were the same by accident:
this one is the one i meant to put also:
http://www.sears.com/sr/javasr/produ...id=02871224000
? thanks for the reply, but they are all diehard from sears? and the one they have for sale of 39.99 is a manual one.
i like the one that goes 15/2/100, is that too overkill?
they also have one for 12/2/75, but at the current time period the one that does 15/2/100 is actually on sale for 5 dollars less then the other one.
i also have a motorcycle but i think its 12 volt not 6 so i could probably use the trickle charge of 2 amps for that durring the winter also with eiter of those?
do you think i would ever need a 6 volt capable one? (i know it depends, but generally..)
lol im with you low, i also work for sears in the auto center. front ends department
a charger is really just a charger though. best way to charge a battery is a slow trickle. dont need a fancy charger. i think mines from the 80's
jackpawt883
09-10-2015 08:53 PM
