Best Rust Killer
Best Rust Killer
my car has a rusty chasis so i decided the most economical way to deal with it would be to crawl under it and paint it with some kind of enamel
does anyone have experience with this situation and would like to give me some insight as to whats the best?
ive heard good things about por 15 they are the most expensive but i found a site which sells a complete undercarrage kit which includes (marine clean, metal ready, and por 15 in quart sizes) for 45 +tax and shiping
how important is metal ready and cleaner
thanx for any info you can give me
your prep work always will show in the end so no step skipping.The metal ready and cleaner is very important.But with the way por15 works.All you really need is a wire brush.Do not get that stuff on your skin Only time removes it (2-weeks)
Location: Chillin' with Frank, Dino, Sammy and Pete at the Sands!
Originally posted by Damon
POR works. Scrape off the big rusty chunks and slather it on. Doesn't get much simpler than that.
Has anyone tried the clear POR15? I have a few bubbles forming on the body of the '91 GTA that I recently acquired.
I'd rather go clear so I won't have to do so many coats of duplicolor or sealer but if the black stuff works better, then that's what I'll get.
i think that the silver is the thickest version and the clear is the thinnest with por 15
so if i use por 15 on my rusty chasis do i need to use the marine clean and the metal ready or should i just wire brush because they cost extra money and if they arent really needed then id rather not get them. how much better do they actually make it work anyway?
brothaslide
01-09-2016 12:11 PM
