Brodix for 1000$ or Vortec for 600$?
Don't wanna take up all your time here, so I'll make this fast.
I was planning on buying Brodix IK200 aluminum heads for $1000.
200cc Intake ports
64cc Combustion Chambers
1.470'' Dual Valve Springs
(125 lbs. Closed / 325 lbs. Open).575'' Max lift
2.02''/1.60'' Valves
Straight Plug
Assemble
Friend of mine wants to sell me his Vortec heads from Pro Topline. They are Iron. He wants 600$ for them. Is that even a good price for these heads? I'm pretty sure I can get them for that price brand new.
170cc intake runners
1.94/1.5 valves
120lbs closed, 275lbs open springs, good for .540 lift
What deal here would be a better deal? Will brodix really make that much more power to where it would be worth 400$ more? Keep in mind that if I do the vortecs I might be able to go with a new TPI baseplate from edelbrock.
Thanks!
_Clark
200cc Intake ports
Straight Plug
Assemble
1.94/1.5 valves
Thanks!
_Clark
Re: Brodix for 1000$ or Vortec for 600$?
I'd go with the Brodix, I cannot stand iron heads. Not to mention you'd need a whole new intake to go with the Vortec intake ports. I don't know if the straight plug would cause any fitment problems with whatever manifolds/headers you are using. Looks like you can run a bigger cam with the Brodix heads as well.
I'm only going to be running a .452/.465 Lift 214/220 Duration cam. I was thinking I could port the vortecs out a little as well. But you are right about the intake, I would have to get a new baseplate for my TPI now wouldnt I?
Also, I think he's throwing in a set of Comp 1.52 Roller Rockers...still have to clear that up. The heads are already assembled.
Originally Posted by robvas
I'd go with the Vortecs, those Brodix heads are better suited for a serious 11 second (or quicker) setup. Your low end would suffer with them.
GM Performance Parts makes a Vortec TPI base
Originally Posted by Gunny Highway
Trick Flows
The IK200s flow better than the Kenny Dutweiler series Trick Flow heads. Trust me I did a LOT of research. If I am putting $1000+ into my car, it's going to be well freaking worth it.
Alright guys, after reading the responses from you and the guys from Thirdgen, I have decided to go with the Brodix Aluminums, seeing as I would have to spend 400$ on a Vortec baseplate anyhow. Besides, this leaves me open for an HSR or an LT1 swap in the future. Thanks for your input.
_Clark
_Clark
