cams too big
cams too big
what are you guys using for 10.4:1 compression 383 with afr 190's hooker long tubes mufflex 4" automatic trans. I have the zz9x that tpis said would be awesome the only awesome thing about it was the price.
I heard talk about the hot cam and the 309.
Any thoughts??
Any thoughts??
What are the cam specs? Mine are in the sig and its just a 355 that runs mid 13's on "factory" programming.
-Brad C?
355ci '89 Iroc-Z Red, T-tops, power everything, A4,New 10 bolt w/ 3.73's
Trans-Go shift kit Corvette Servo,Accel 8.8mm wires,Flowmaster 80 series ,K&N's, !MAF Screens, Hollowed out airboxes,homemade Subframes. Kieth Black pistons 10.3:1, Comp Cams 270H (.495/.502 218*/224* 110*LSA) & valve springs, SLP 1 3/4" headers, TCI 2400 stall, Dual Roller timing chain, 2 3/4" I-pipe.
Full street trim best run:14.799/mph:93/60': 2.02 (last year) New Times to come.
New times: 13.732 @ 99.30 on a 1.878 60'
Pics of the Iroc
-Brad C?
Pics of the Iroc
what rear gear and conv. you running? you should have around3:42-3:73 w/tpi's and you need prolly about 3K stall conv. and you should be able to use 248 or 25x deg. duration @.050 and prolly .600 lift or so should be in the ball park. my eng. hasabout 10:1 and runs great w/242 @ .050 cam (solid)but I have 3:73s and 2500ish stall conv.) I still get 11 mpg. too believe it or not w/a carb.
but Id call comp. cams help line.
good luck chris
1986 Iroc Z
355, cleaned up trick flow twisted wedge G1 heads, 750 holley, 700r4, 10:1 compr., forged flat tops, solidcam .501I .510E, 4gen rear w/3:73 posi, girdle, and disc's, Edel. torker II, shift kit, 2500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd 6al, coil, dist., mallory wires.
12.86 @109mph so far(still need fine tuning)
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
good luck chris
1986 Iroc Z
jasonduaine
04-01-2015 08:09 PM
