Can a Carbed 84 305 H.O be a 14 sec ride
#16
I have an 84 Z' H.O. Vin.G L69
I dont know how many 305 H.O. owners know this but the H.O.s came stock with 373 gears. My Z has the 700R4 with a few light mods: Accel super coil, superchip, shift kit, stock carb is raised from the manifold which proved to be pretty good, this allows more room for the fuel and air to mix and it is further from your engine (less heat). But if you decide to do this watch your height cause the stock dual snorkle air filter will hit the hood. Alot to do with the lower power rating on the car was the addition of so many emmisions equipment. But I love my HO. Another thing that cant hurt is drag radials. Mine shifts hard in 2nd and easily loses grip sending my a$$ side ways. And Stangehunters right Sub frame connectors is a must unibodies are notorious for sags and cracks due to the amount of torsional stress the undergo. A strut tower brace probably wouldn't hurt either. Edelbrock and Hotchkis both make strut tower braces for carbed cars.
Take care.
Boz
Take care.
Boz
#17
I agree. In my opinion, one of the first things I would recommend to anyone thinking about majorly moding their ride would be the suspension, because your car is only worth anything if it can make that power stick to the ground. After that, mod the hell out of it. But you will be sorry if you just drop the motor in and think its smooth sailing. Also, the things I have mentioned such as SFC's and STB and so one will help lower those E.T.'s dramatically. You'd be surprised. My 305 could proly have ET's in the 14 with alot of suspension work and only 165 hp. Its a combination of things that make your car fast, not just one aspect such as power. Hope that helps!
Will
'86 Z-28 305 c.i. LG4
Rochester QuadraJet 4bbl
Flowmaster 80 series Chrome Tips
Dual Snorkel Air Cleaner
K&N Filter
Michellin P215/65/R15 X-Radial Plus
Lots of Mods on the way
Pioneer 4"x6" dash
Pioneer 6"x9" rear
Alpine 8" Type S in bandpass box
Alpine Amp 300x1 bridged
Sony 4000X- x-Plode Deck 50w x4
Soon to be sporting Hooker SuperComp Shorties, CompCam Xtreme 256H, Edelbrock Performer EGR, World Sr Torquer 305's, DynoMax Super Converter, and American Thunder 3" Cat-Back !!!
http://camaroz28.cardomain.com/id/stanghunter211
Will
K&N Filter
Pioneer 4"x6" dash
Pioneer 6"x9" rear
#18
Check out signature. First time is from
my near stock 84 305 HO with some select suspension mods....
Tom K.
1984 Z-28
305 HO M5
pulleys,coil,3:73(stock)
Jet chip,Al shaft,1.6arms
LCA+brackets,BFG DR's 14.20 @ 96.74 2.02 60FT.
Tom K.
1984 Z-28
305 HO M5
#19
start with a trip to your friendly neighborhood u-pull-it. aluminum driveshafts are fairly common. just walk around all the f-bodies and look under them, if the drive shaft is grey you found a winner, most yards only charge like $15 for a shaft.
another great salvage yard grab is always aluminum brake drums for those stuck with iron. i know most of the L69 cars got discs or aluminum drums from teh factory, but if you have steel or some garage mechanic has swapped iron for your stock aluminums just look for a grey brake drum with colling fins that look big and have no lip on teh back of them, they will also have round balance weights instead o fthe rectangular ones iron drums use. saves about 5-9lbs each.
now if you know anyone who welds it is time for a trip to home depot/lowes. they sell 4ft long pieces of strap steel, 1/4 thick and 2 inch wide, for about $6. cut it to length and weld it into teh bottom of the stock control arms and BLAMO!!!! instant boxed control arms. if you really feel adventurou8s you can order poly(energy suspension) or aluminum(competition engineering) bushings for them too fro about $40 and have them installed at a local garage for a few bucks.
then when you hit the track just drop one end link off the front sway bar to let it lean back a little harder and you shoudl have plenty to get itnot eh14's. one thing about stick cars is to learn how it wants to launch. so play aroudn with rpm and how you let off the clutch a bit.
later
tim
NJ SPEEDER
91 Camaro RS
305TBI/700R4
12's Coming Soon
2nd Annual East Coast F-Body Nationals
July 20,2002
www.geocities.com/njspeeder
My MAFB.ORG Home Page
http://www.mycar.net/mafb/registry/detail.cfm?id=299
later
tim
NJ SPEEDER
91 Camaro RS
305TBI/700R4
12's Coming Soon
July 20,2002
#20
thanks guys for the help i knew it felt pretty healthy for a 305.when i got the car it had an exhaust already on it from the guy that had it before me.i dont know what it is but it sounds realy good (some what like the dukes of hazard charger).so hopefully i'll be able to post in the kill forum against imports at my school.i guess the only ones i'll have to worry about are Type R Integras
#21
Is yours the anniversary edition, with Recaros, 4 wheel disc, 16" wheels etc? If so that is a sweet ride! The L69 can perform well with a few mods.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
Mario,
White 94 Z28
Video
Black 87 IROC-Z
#22
<font face="Verdana, Arial" size="2">Originally posted by Z28ROC:
</font>
</font>
yeah its the anniversary editon.i love the seats in it but i would like to find were to buy new ones mine are old and worn out(probley cost a lot).i think its the first f-body to have 16inch rims too.
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
