Can i change my gauges?
K..i have an 84 2.8l camaro...and have you ever seen the gauges..the speedometer has mph on one side then clicks on the other..and the fuel gauge has galons and litres...and i want to know if i can switch to the newer model style....you know what i mean? can i just plug in the new ones and go?..
dave
dave
I'm prety sure that you can use any gauge cluster up until '89 (90 was when they changed to electronic speedo right?)
Its a fairly easy swap to do, biggest pain is getting the speedo cable off the old cluster while its still in the dash
armedtrigger
02-24-2015 08:30 PM
99TransAmWS6
02-12-2015 07:23 PM
