can i flat out swap these parts?
ive got a 91 5.0 305 camaro rs and im wanting to do some more modifying, im wanting to put the tpi setup on it will all the parts fit directly on my tbi setup or do i need to do alot of modifications? and also will it be worth it.
what im going to try to do is buy the setup whole like off ebay or go pull it at a junk yard manifold and everything and im going to get the ram air box for it.
will all the cables and evything i need to switch fit right on?
any info appreciated
Re: can i flat out swap these parts?
you have the later style heads, 87 and up, which means you are better off using 87 or later intake, because the bolt pattern differs slightly
it will bolt up, and as long as u get the proper wiring and computer it will work fine
there may be a problem with vats
doing a search can help you find more info about the swap and about vats
12-04-2014 11:56 AM
