car wont move forward
new problem,
car idles fine and revs fine when idling, but wont move forward without heavy choking and sputtering and trying to die.
i tried to check engine codes and it wont even flash.
I just put new headers and exhaust in last night and it has been doing this since i finished.
i have checked all my wires, and everything seems fine.
all the air pump lines and cat have been removed
i have also posted this here:
http://www.thirdgen.org/techboard/te...e-forward.html
Re: car wont move forward
Do you have an air leak after your MAF somewhere? I'd be thinking it was some sort of vacuum leak. Spray some carb cleaner around your engine and if the idle changes, you've pinpointed your leak.
Go back and look oever ALL connectors on the engine. Something probably didnt get plugged back in after your header install, or something got accidentally unplugged when you removed your AIR pump that shouldn't have. If this problem just started right after your header install, 98% odds say it's something simple as that.
kinda found the problem.
i think the wire to the o2 sensor was grounding out, it looked a little melted.
there is one other wire bundled with the o2 going to another sensor. could the other sensor cause this problem?
I replaced the o2 wire and rerouted and zap strapped it and still havingthe same issue
Its wierd, i removed the cap and cleaned the connectors and it drove fine to 4000rpm then crapped out again, about 10min later it started crapping out all over the rpm range again. mostly between 2-4
