Carb guys looking for more air than stock...
check out this place. I found the parts I need for my salvaged dual snorkel air cleaner. This may be old news for some, but I've looked all over for this stuff.
http://www.ramairbox.com/home_page.html
Re: Carb guys looking for more air than stock...
would that fit a stock camaro or would you have to make room ?
theres usually allot of hoses in the way , if you want you can go ghetto and get another air cleaner cut off the snorkel part and just spot weld it onto your original air cleaner , it works cause you can choose wear your other snorkle goes , i cant spell
i emailed them to get info about the air intakes that run to the front of the car on the passenger side (i think it's part # 14070917LH) and the stock hoses. here is a copy the email the they sent me.
model=iroc z28
year=1986
Order Info=Hi,
I hope you have what I need. It looks like you do. I have the dual snorkel air cleaner from an 305 HO. I do not have any of the hoses and will also need the left hand snorkel(if you are looking at the car from the front).
please email me at davidl.smith@carlson.com
you are talking about
part #'s 14070917LH and of course the other one 14070918RH.
GM has discontinued these items.
AIS now reproduces these .
These are sold as AIS part # 917 & 918
They are fiberglass reproductions of the originals.
They go for $42.50 Each.
#918 is the passemger side intake.
We also offerpart # G28108, fatory style replacement tube
Part # G28108 is $17.95
model=iroc z28
year=1986
Order Info=Hi,
I have an original dual snorkel air cleaner set up off an 84 z28 if anyones interested. The passenger side plastic scoop has a small piece cracked off and the hose part is abit ragged but the cleaner itself is solid.
Orignial dual snorkel pieces are getting pretty rare. Good to know that a company like Air Inlet Systems is making some repro-pieces to fill in the gaps for stuff you can't fine in junkyard very easily any more.
95chwagon
01-13-2015 09:19 PM
