Check engine light
Check engine light
Thanks,
For the engine codes, but code 32 Barometric Pressure (BARO) Sensor Circuit failure.I called the GM dealer they don't have a clue what this is or where it is located. Can anybody help me.L98 engine 1992 Z28.I have changed the EGR Valve & Solinoid.
Re: Check engine light
on the firewall near the drivers side,
if you look at the engine, from under the hood its on the right of the brake booster
thats where it is on my car, the map sensor is located on the passenger side
Code 32 is for the EGR. Going thru the flow chart, there is nothing there for checking the BARO. You list you already changed the EGR valve and solonoid. May be a wiring problem or electrical open.
The BARO is monitored thru the MAP sensor. At key on engine off (KOEO), the sensor uses that reading for Baro pressure. Once the engine is started and running, that is the info the computer uses thru that key cycle. Then the MAP takes over reading engine vacuum.
01-05-2015 07:14 PM
