code 23 on 305 TBI 89RS camaro
Re: code 23 on 305 TBI 89RS camaro
23 Manifold Air Temperature (MAT) sensor
Faulty MAT sensor.
Faulty or loose wiring and/or connections to the MAT sensor.
I copied and pasted this off www.iroczone.com/specs/TroubleCodes.htm
Faulty MAT sensor.
M/C would be mixture control solenoid on a carburetor car. The book you're using is outdated. The correct problem on your car is described by 1987IROC350 above. The wiring for your MAT sensor is shorted or open, or the sensor has failed.
12-05-2014 11:42 AM
12-01-2014 08:08 AM
07-04-2005 05:00 PM
