Code 32 with gutted cat and cutout?
Well, recently after I gutted my cat and put my cut out on, I started to get a code 32 while going down the highway. It only happens when I go down the highway and after about 5 minutes of driving. Every once in a while, it will shut off after about 15 minutes or so. Does or did anyone else havethis problem? If so, what do I need to do to fix it?
Code 32 for that is an EGR code because that is what I got when I added the Superram Kit and headers. A little trip to LPE and the performance was improved, car ran excellent and the code was gone. He reprogrammed the EPROM. Now that he is hurt, I don't know if they are doing that. LPE needs you to have the car there to do real time testing so they can get it nuts on. I go to www.fasterproms.com and they burnt me one for my setup, had me do runs and take readings, do another burn and redo the reading and reburn just to make sure. Car is always running, data is realtime and results are fantastic.
No financial gain. Just a satisfied customer.
CamaroZBoy
09-09-2002 10:33 AM
CamaroZBoy
09-01-2002 09:48 AM
