Converted to non-computer carb setup and aving trans/idle problems..
I put a 650 DP and HEI distributor on my 84z28 that had the cc-Q Jet. When I put the car in gear it wants to stall out on me. And wont dle while in gear unless I set the idle t like 1200 RPM's. I cant figure it out. Could it be the converter trying to lockup now that I disconnected the computer. Need help fast! Derek
Re: Converted to non-computer carb setup and aving trans/idle problems..
derek, to eliminate that poss. try unpluging the 4pin conn. on the drivers side of your trans. if thats happening, then it should clear up. I doubt thats the prob., but its worth a shot. did the car run correctly before you did the swap? if so, then there has to be something wrong w/the carb, the way the carb is tuned(Idle mixture screws or needle and seat's), or the dist. may have a weak spark at low rpms. are the dist. and carb new? if not, did they work good on prev. car?
chris
chris
