Cooling Problem....HELP
Here's the skinny. Just got this 92RS from origional owner. Cars got 133K and runs fine has a new radiator but it's running too hot. At normal speed according to the gauge around 220 when sit and stop goes up to around 240 range. I'm thinking a new water pump, therm, and a flush to go with that new radiator and a pint of water wetter. Any ideas? I haven't driven it since I saw this happen so timely responses would be appreciated.
Former F-Bod's:
96 Z28 A4, Airfoil, !TB, !MAF, K&N Filter
89 RS 305/auto
86 Z28 305/Auto
86 LT 305/Auto
86 Firebird 305/auto
81 Z28 350/auto
Currently F-Body-less
2000 S-10 '4 banger with a K&N filter'
I'm Baaaack 92RS 305/auto
Former F-Bod's:
89 RS 305/auto
86 Z28 305/Auto
86 LT 305/Auto
81 Z28 350/auto
I know a few people that have tried the Stewart Stage 1 water pump and noticed a good temp. drop. Make sure there isn't a bunch of leaves and stuff between the radiator and condensor. Also, make sure the support spring is in the bottom radiator hose..if it isn't the hose could be collapsing, restricting coolant flow. Make sure the radiator is flowing well..let it get warm and feel along the radiotor..any cold spots and that's where it is clogged.
If you're not losing coolant, consider getting a lower temp fan switch put in. I just bought one for my 1984 Z28. Same problem lead me to make that purchase. I posted here a couple of days ago and was advised re: the fan switch. The guy at the speed shop said the same thing. Let me know how it goes and good luck!
Tracey
1984 Camaro Z28
305 c.i. LG4
Rochester Quadrajet 4-barrel carb
5 spd trans.
Accel Superstock wires
Accel dist. cap & rotor
Bosch platinum plugs
K&N air filter
Dynomax Super Converter
Dynomax Super Turbo muffler
chrome tips
Cooper Cobra 235/60R/15 (fronts)
Cooper Cobra 245/60R/15 (rears)
160F thermostat
...and more to come!
http://members.rogers.com/copperchick010
Tracey
1984 Camaro Z28
305 c.i. LG4
5 spd trans.
K&N air filter
chrome tips
160F thermostat
MAKE SURE THE FANS ARE COMING ON first...
They are what cools the engine while idling.
Make sure you run a decent 50/50 mix of water and coolant. Maybe add a bottle of Redline Water Wetter also.
It could be the water pump but check all of the above first. Even add a manual fan switch so you can turn both fans on at the same time whenever you want. Mine works like a charm!! Goodluck
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Denny Villemure
www.denny.cz28.com
I recently changed to Edelbrock headers on my T/A GTA -88. After this my fan wonīt start. The temp raise to 215 in say 3min on idle, but the fan doesnīt start.
When I changed to headers I cracked the sensor on passengerside, but I changed it right away.
When I turn the ignition, the fan turns and stops directly.
Anyone familiar with this problem?
Pontiac T/A GTA 350 (L98)-88,TH700, TransGo shiftkit, Edelbrock headers, Holley adj fuel reg, Accell SuperCoil and 8.8mm spark, no catīs,JR airfilter
Get a lower temp fan sensor. The stock one on a TBI 305 Camaro RS does not turn the fan on until 244 degrees.
91 Camaro RS
Too many mods to list here
81 Ford F100 300 6 cyl (daily driver)
Pacific full suspension MTN bike
Pacific front suspension MTN bike
(spare tires for the Ford LOL)
http://www.quick91rs.cz28.com
91 Camaro RS
Ahh, that was rigt. I didnīt want to run the engine over 221*F, so I shut it down. Today I let it go, and the fan started at 225*F. Sorry, I didnīt know about that, Iīve only owned the car for a month. Need to install that fan-switch.
Thank You very much
Thank You very much
CARiD
09-30-2015 05:44 AM
cmsmith
09-14-2015 09:09 PM
