Cracked Flexplate
Cracked Flexplate
Anyone had their flexplate crack up on them?? Car developed a noise that initially sounded like a lifter tick. After a 130 mph run down the freeway, it got a lot louder. Pulled the dust cover off, and low and behold, cracks from the outside in, and all around the center section. Just curious if anyone else has had this happen to them.
Re: Cracked Flexplate
new one is $30 at Autozone
Rough starting yes, because the ring gear doesn't line up with the starter like it should.
I didn't have a problem with surging but anything's possible...and since 4th gear is when the TC locks up, it makes sense that it would be worse then.
