Cranks long time before starting
Old 08-14-2002, 12:15 AM
  #16
RODS92Z's Avatar
Post
UMM, Try starting with something simple. Like a clogged fuel filter, or bad plugs. Sounds like your over due for a new fuel filter.
1992 "25th Anniversary Z-28 Custom Heritage Edition, 355 TPI, Auto, 2.73 Posi Rear, Arctic white w/ medium mettalic gray stripes with black border stripe, charcoal interior
1967 Pontiac Catalina 2 door fastback, 400 V-8, Auto, cameo ivory white with burgandy interior.
1987 Olds Cutlass Supreme, 350 Rocket, auto, medium gray with light gray interior.
1971 Monte Carlo, tuxedo black, 350 V8
1971 Monte Carlo, blue, 350 V8
RODS92Z is offline
Old 08-14-2002, 11:33 AM
  #17
slimdawson's Avatar
Post
Try cranking and watching the oil psi gage. If it cranks and cranks and nothing happens until the oil psi goes up, it may be your fuel pump relay, as someone mentioned earlier. Mine went too. You could override the relay and see if it cranks, then you will know.
Pix of my rides!
Finally have some pictures of Y2k Vette wheels, motor, etc.
*1991 Camaro RS !LO3
8.65@84.3mph NA
*1988 Mustang 5.0 7.92@87 NA- For Sale
*1988 Mustang GT 'vert
9.56@73-bone stock
*1986 Kawasaki Ninja 1000R 7.30@100mph
*1987 Honda CRX Si 16.5@85mph-stock
100% American!
slimdawson is offline
Old 08-14-2002, 01:05 PM
  #18
91RS5speed's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by mr diabolical:
fuel pump relay could be out. it wouldnt activate the pump until sufficient oil pressure was reached (cranking over). the pump will only work off the oil pressure sensor, it uses the relay for start up.
</font>
My vote goes with this one. I had a simular problem turned out to be the fuel pump relay. When you turn the key in the on position do you hear the fuel pump turn on?
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
91RS5speed is offline
rideordie
11-05-2019 04:52 PM
AdsoYo
05-02-2018 03:21 AM
Jessie4tin
01-07-2015 08:53 AM
cmdeshon
12-12-2014 10:51 PM
Snoman73
11-17-2014 07:22 PM
Quick Reply: Cranks long time before starting
