dimmer switch
first disconnect the elect. connector of the multifunction lever, located under the steering wheel. Remove the protective covering from the wire. Grasp the lever firmly, twist and pull(the tang on the lever must align with the socket) the lever straight out. Pull the wire thru.
When you put it back in. Be sure to use a thin wire to pull the wire back thru the steering wheel. Might be a good thing to tie off the wire after you disconnect it with another piece that way you don't have to thread it back thru by hand. you just pull both ways.
jackpawt883
09-10-2015 08:53 PM
