disk break locking up warning
i found out the other day the hard way that most of the time when a disk break caliper locks up, its most likely not the caliper at all, its the break line itself that connects to the caliper, its notorious in camaros that this break line implodes. I wasted money on a new caliper and pads and i didnt even need them. Its always a good idea to replace both lines and bleed your breaks once in awhile especially if the car has been sitting.
If your breaks are locking up its generally rule of thumb to replce the calipers and lines all together. That's what I did with my front brakes two years ago and no problems yet.
Camaro brakes are chep anyway!
Great time to replace them all with an Earl's Hyperfirm SS braided kit. They really wake up our brakes. My factory lines carried me through 10 yrs. These will probably outlast the car.
92BLKL98
'92 Black Z28 Hardtop w/Harwood 2" cowl ind. hood Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods Random Technology cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
92BLKL98
Another often overlooked cause is caliper-to-knuckle clearance. Alot of times rust buildup occurs and makes the caliper drag. Next time you have the calipers off, take a file or something and clean all the rust off the knuckle where the caliper rides and lubricate it w/ silicone grease.
But usually the #1 cause for your situation is the brake lines.
Webmaster:SETHIRDGEN
GM Tech
ASE Master Auto Technician + L1
1987 Trans Am: 357ci
Ported TFS heads, ZZ4 cam, headers & exhuast and other go fast goodies
13.53 @ 103.77
GM Tech
13.53 @ 103.77
