DO I NEED A CUSTOM CHIP CAUSE OF MY MODS?
Old 07-02-2002 | 09:44 PM
STAYBG's Avatar
Question DO I NEED A CUSTOM CHIP CAUSE OF MY MODS?
well i dont have a ton of mods to my car but i think there enough to get a chip burned but kinda need a second opinion.i have a 87 iroc and it had a 305 tpi in it.but know it has a 355 with .30 over pistons and a crane compucam part#114112 in jegs and the specs are duration=254/264 lift=.401/.423.also the mods in my sig. so any info would be appreciated.thanks.
1987 IROC-Z28
355 TPI
58MM HOLLEY TB
HOME PORTED PLENUM
LT1 INJECTORS
HEDMAN HEADERS
CRANE AFPR
MSD WIRES
JET FAN SWITCH.
3' 2chamber flowmaster cat-back system
STILL TO COME,
3:73 POSI DISK REAR
4' COWL HOOD
4TH GEN INTERIOR
ALL AROUND SUSPENSION KIT
[This message has been edited by STAYBG (edited July 02, 2002).]
Old 07-03-2002 | 12:03 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Post
With the LT1 24# injectors, yes definitely. Every car can benefit from a custom chip.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
Old 07-03-2002 | 01:21 AM
aklim's Avatar
Post
I have one from www.fasterproms.com and am very pleased with the results and the great tech support for diagnosing some other issues I had at the time. They get a chip as close as possible based on your mods and them have you make runs with monitoring equipment and them burn the chip till they get it on the money. They are around $500 for the first chip but after that, if you do more serious mods and need a new chip, it is around $150
[This message has been edited by aklim (edited July 03, 2002).]
Old 07-03-2002 | 01:25 PM
RedIrocZ-28's Avatar
Post
I have only spent around $400 and I can burn chips indefinitely. There are no more costs and I can Dyno tune and road tune my car myself.
$500+$150 for each subsequent burn=Too much money.
By The way, your cam is way too small. Those lift numbers are lower than a factory L98 cam ever was. You would benefit from a cam with lift closer to .480 or so.
[This message has been edited by RedIrocZ-28 (edited July 03, 2002).]
Old 07-03-2002 | 01:38 PM
khbws6's Avatar
Thumbs up
For all you third gen folks, I will burn you a chip for $125, custom to your vehicle. Check out my website http://www.lt1tuning.com
I am just now getting this site setup and I don't have the order form posted yet or pricing. I should be able to do everything within a couple weeks. Check out my car it's the 91Z on the picture page. I custom burned my own chip. The car runs perfect with my mods and it's speed density, not mass air. My car was posted in GMHTP a couple of years ago, thats where the picture is taken from. I will be happy to give a discount for the first chip you order from me. Send me an email if you have any questions. Thanks.
Old 07-03-2002 | 02:11 PM
Zepher's Avatar
Post
I just visited your site. I think you should change the color scheme, kinda hard to read, blue on gray on the main page and black on dark blue on the movies page.
I need to add a chip burning page to my site, as I do programming as well.
1986 Trans Am WS6
LT4 350, LT4 Hot Cam, T56, 52mm TB, MSD 6A & Blaster 3 Coil,
LT1 3.42 Posi/Disc Rear, Lakewood LCA's & Adjustable Panhard Bar,
Eibach Lowering Springs, 17x9 WS6 Wheels, T-Tops,
Custom 4" CAI w/ K&N Filter, 160*stat.
Autometer TriplePod with Phantom A/F & Boost Gauges.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph This was with the LG4 carb setup.
WS6 Trans Am.
Old 07-03-2002 | 02:40 PM
khbws6's Avatar
Post
I threw the site together pretty quick. I agree the movie page is hard to read but the main page is not difficult. I haven't had much time to play with it. I am also in the process of building the Mail server. Thanks for the input.
Old 07-04-2002 | 12:28 AM
airdeano's Avatar
Post
ummm $500 for a custom chip is too high.
and for your mods $300 is too high.
for $500 you can buy your own equipment to
burn chips, buy software to do it and curve
it to your expecations.
if ya wanna call me i can help you out in
your choice
501-6870888 m-f 8-5cst
airdeano
Old 07-04-2002 | 10:16 AM
aklim's Avatar
Post
Had a friend who got hold of a DFI unit which is similar to what we are talking about. Custom tune on the fly. Worked good, real good. 6 months later, I helped him R & R his motor. Burnt valves and pistons. I asked him how he tuned the unit. He said he did it till it felt really good.
Equipment is necessary. However, experience is invaluable. How do you know when too far is too far? Either that or you might not be getting everything out of the motor you could. I went with someone reputable and recommended by Lingenfelter Perf Engr.
Old 07-04-2002 | 10:51 AM
super83Z's Avatar
Post
Did your friend pay attention to the scantool to see how the car was reacting to the programming? sounds like he had too much timing or his fuel tables were off. BTW all these guys are not talking bout DFI they are talking about burning chips for the GM ECM.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28
Superramed roller 406 10.5 compression, AFR 195's and custom cam.
future mods:
N20 waiting to be installed
Wifes new car:
1995 Z28
AT, leather, T-tops bone stock for now. 250 RWHP 300 RWT 14.0 @ 99 MPH on a 2.2 60'
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone (maybe)
Old 07-04-2002 | 02:16 PM
aklim's Avatar
Post
Yes he did pay attention to the timing and fuel curves. Unfortunately he did not know what to look out for.
I had an unrelated issue but my car would not run right.I sent my diacom to www.fasterproms.com and they said that the injector pulses were way too much for what was happening and we found out that it was a shorted injector bank. The car would be puking fuel out but yet we could see that it was running lean according to the diacom. Turns out that the injector pulses were supposed to be around 1.5 ms at idle and they were around 3.5 ms instead. The shorted out bank was on the driver side where the O2 sensor was and the other side was compensating. Without their help, I would not have know that 3.5 ms was too high for idle. Since I had an AFPR and larger injectors and no experience, I could not tell how long was too long.
DIF is the same thing a burning your own chip. In either case, you are altering the way events are handled. With the DFI, you are doing it on the fly whereas with the chip burning, you are stopping and taking it out and doing it then reinserting the chip. Same principle in either case.
Old 07-04-2002 | 02:19 PM
STAYBG's Avatar
Post
HEY GUYS WHAT EXACTLY IS DIF OR DFI?
1987 IROC-Z28
355 TPI
58MM HOLLEY TB
HOME PORTED PLENUM
LT1 INJECTORS
HEDMAN HEADERS
CRANE AFPR
MSD WIRES
JET FAN SWITCH.
3' 2 chamber flowmaster cat-back system.
STILL TO COME,
3:73 POSI DISK REAR
4' COWL HOOD
4TH GEN INTERIOR
Old 07-04-2002 | 04:26 PM
aklim's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by STAYBG:
</font>
http://www.mrgasket.com/pdf/DFI.pdf
It allows you to program everything you want to in the car. Don't know about DIF tho. DFI stands for Digital Fuel Injection, I believe.
Jasonz28camaro
West South Central
06-07-2015 09:12 PM
96SilverRam
05-05-2015 09:56 PM
Fusion93Z
09-10-2002 06:46 PM
Wilson
07-21-2002 05:08 PM
Wilson
07-21-2002 04:58 PM
Quick Reply: DO I NEED A CUSTOM CHIP CAUSE OF MY MODS?
