Do we have angle plug or straight plug heads?????
just what the subject asks, because when i look into getting some new heads, there are angle plug and straight plug heads...and i was just wondering!
OEMs are straight plug style. You can get which ever you want, but be cautious as some headers will not work with angle plug heads. The reason for angling the plug is to get the spark closer to the exhaust valve ... I forget the reasoning. Maybe a better burn.
Originally posted by Black91Z28
and let me ask u this.....is 68cc better than 72cc??? i would think so but im not sure
LOL No valve shrouding is bad. It is when something (ie. the bore or the combustion chamber) is close to the valve and blocking airflow. Therefore limiting power. You want the most airflow you can get out of a head without loosing velocity.
Vavle shrouding = BAD
Martin
Martin
oldschool
02-09-2016 09:21 PM
