DTC 32 EGR Valve
DTC 32 EGR Valve
I keep getting a trouble code 32 for the EGR valve on a 1992 Camaro RS with the 350 L98. I've replaced the EGR valve, solenoid, and most of the accessible hoses/tubes. No luck! The engine still runs rough and the code continues. Any suggestions from anyone???
Re: DTC 32 EGR Valve
Did you clear the trouble code and replace the part? Or did you just replace the part? To clear the original code disconnect the battery for a minimum of 20 minutes. It might not realize you replaced it.
