Emission Hose Routing
Can anyone send me the emission hose routing for 305 TPI . since the 92 Camaro that we have was a front end collision , the hood is not original, and has vacuum routing for MFPI. Any help would be greatly app.
Re: Emission Hose Routing
Did they make a '92 305 T"P"i,?? I thought the 305's were only T"B"i.
I might be able to send you one if I have a specific description.:
MAF sensor or MAP?
TPI or TBI?
305 or 350?
year of motor?
MAF sensor or MAP?
TPI or TBI?
305 or 350?
year of motor?
It is a 92 Z28 convertible, with the original 305 TPI, I believe it has a MAF sensor. What I need is to know the routing of vacuum hoses to EGR valve from the vacuum selenoid and intake manifold vacuum port.The EGR valve is located under the plenum as is the MAT sensor.
