Engine Removal
Engine Removal
Im pulling the engine out in my iroc and I had a few quick questions. The whole top end of the engine is already off including the heads. Where is the best spot to attach the chain for the cherry picker? Also, the bell housing bolts and motor mount bolts are removed, do I need to remove the flex plate bolts also? Will I run into any problems as far as the engine and trans being connected? Any tips are helpful, thanks!
The radiator, harness, and drive shaft are already out. The only thing left in the engine compartment is the block, and the ac/heater plenum. I would have to put the bell housing bolts back in though.
Mikes 1994 z28
11-25-2014 02:00 PM
centric
08-15-2002 09:04 PM
Darth Xed
13
07-22-2002 12:45 PM
