engine swap....how tough?
I recently purchased a '90 Formula with a 305 TBI, just under 130,000 miles. When I bought it, the engine fired right up, no hesitation, and didn't smoke.....well, lo' and behold 2 weeks later, it is having difficulty staying at idle when first started, and it's smoking...I believe it's burning oil.
Now, this was a "budget buy" in the first place, and I don't have a whole lot of money to spend on this car, but it does have to be reliable. So my question is, how tough is a motor swap? I have never done it before, but I do have a buddy (older guy I used to work for) who would supervise (he's done this work plenty of times before). So it would be me, with no experience, some tools, a "how-to" book, and a little supervision.
On a side note, i'm in the military, so I have very minimal mechanical experience, but hope to be starting school soon to be a mechanic when my enlistment is up. So I have a high interest in doing this, but my question is how difficult is it and would you recommend I attempt this?
And the swap would probably be to a 350 TPI or an LT1...cuz the LS1 is too expensive
A straight swap from the 305 long block to a 350 longblock with the later model heads and re-using your current fuel system is a weekend job easily.
Once you start swapping TPI for TBI, or going with the LT1 and dealing with opti spark things get a little more complicated.
You could swap a good L98 long block in with your current set-up and then do the TPI or whatever other fuel system upgrade after you get the actual bottem end and heads swapped in and running. That way you know you have a good bottem end to work with.
Ah yes, maybe I should clear that up. My SS is in storage...and is going to be in storage for probably 2 years. Full-coverage insurance is killing me, so I have the SS on comprehensive only (can't drive it) and liability on the Firebird. If worst comes to worst, I can fully insure the SS again, but I am doing this to save money until my driving record "calms down" and I can drive it again....I just CAN'T sell it
Putting your TBI on top of a L98 long block works pretty well. A guy on thirdgen.org is running 14.7 with a stock tbi and L98. Its straight forward, pulling the engine is probably a 3-4 day process for someone who's never done it, then putting the new one is is probably 3-4 days, so allocate about a week or two to get it all done. If you're sticking with a stock L98 350 and tbi get a 350 Caprice chip and you'd be doin fine. A 350 knock sensor is also needed, but all the other sensors will be a-ok.
Reno Leigh
07-02-2002 01:08 AM
