exhaust
exhaust
Hey I was wondering if any one could tell me some web sites to find a Dual Flowmaster exhaust from the Headers back. No Y-pipe or the other crap. And I want it to sound pretty loud.
Thanx
Thanx
They don't make duals for these cars in kit form...you have to get the parts together and have it welded up or just get the whole thing custom made. There's not a lot of room under these cars so most guys who want duals don't bother going over the axle, they just pull about 2 feet of pipe off the collectors then go into the mufflers and dump the exhaust right before the rear end. It'll cost you some ground clearance but it'll sound BADA$$.
I ran duals on my 85 T/A recently. I have hooker long tubes and ran dual 2.5 inch pipe with h pipe and dynomax bullet mufflers. For ground clearance the 2 biggest problems I see is going under the crossmember/subframe, and muffler placement. I used bullet mufflers because they are small. If you can have pipes custom bent you could have the pipes ran under the crossmember pretty easy. I used hedman s extension/reducers to move the exhaust to the center in the driveshaft tunnel. I then ran it back to the rear end and put the mufflers and turndowns on it. If you want to use normal mufflers you will have to find somewhere to put them. You could either modify the floorboards to fit them, or run the exhaust either over or under the rear axle and put the mufflers behind the rear axle. You will need to get under the car and study the floorboards and plan out where you want to run everything. It is tight trust me.
Ben
Ben
Originally posted by aklim
True duals are a PITA and totally unnecessary unless you are running 500+ HP IMO.
Ben
Money is the only thing to fabricating. If you wanted you could run it thru the cabin. My issue with true duals is that you end up with a car that you have to "make it work" all for nothing. You will most likely end up with losing something in the process like your ground clearance. Short of going thru the cabin, I have yet to see anyone show me that they have not hurt performance or emmisions (for those states that care) and kept the ground clearance. You make it with too many bends and you will hurt the performance. Either that or reduce your ground clearance which means you may have to do it again when you wear a hole in your exhaust.
I have an SLP 3 in and if necessary I will go to a mufflex 4 in someday. So far with my 3 in, the exhaust is not hitting the bumps which I go over without coming to an almost stop.
No one has been able to show me the power gains. I took my cat back system off at the track and ran the same times. I kept weight constant by removing the exhaust and placing it in back.
Ok, I am not trying to argue that duals are for everyone or that you cant have an awsome single setup, but just that if duals is what you want it is possible. One thing you mentioned was emissions. It is imposible to pass emissions if you have a visual inspection obviously because even if you were to use cats they are not in the correct position which is required. I dont have emissions tests so I dont have to worry about that. I just went and measured my ground clearance and my collectors are the lowest point(hooker long tubes). The flange on my collectors has 4 inches of clearance and the rest has at least 5 inches. Did you look at that link I posted. His exhaust is tucked up even higher than mine because he was able to modify his tranny crossmember and keep his exhaust up higher the whole way back. If you are looking for bolt on performance duals arent it, but if you are willing to work for something unique that sounds awsome then its a possibility.
Ben
Ben
Ben
Oh the cats were there. Just very little in them. I only changed to the single cat a couple years ago. Back then the car came with the 2 cats. Before you check for obstruction in the twin cats you had to remove the "Y" pipe that channeled it to 1 exhaust pipe if you catch my drift. Easier to shine a flashlight into the 2 individual cats when you can remove the "Y" collector after the cat.
use a good header and at least a 3" pipe with a 2 chamber flowmaster and a single out and it will be more than loud enough. go up to 4" and you'll need ear plugs for trips going further than the grocery store.
i wish someone made a really good flowing exhaust that was quiet.
Originally posted by kandied91z
I wish someone made a really good flowing exhaust that was quiet.
05-21-2015 01:04 PM
05-15-2015 10:43 AM
jasonduaine
Exhaust System
03-20-2015 09:00 AM
