exhaust manifold boltz?
the boltz that go into the exhaust manifold, what is the easiest way to get them out? penetrating oil and then let it sit for a while or? please anything will help..and say they do break. i just attempt to drill them out? or? also.. there is a massive amount of wind coming from the back of the manifold and i was wondering would this cause the engine to idle and drive extremely harsh? or? app the help
Douglas
Douglas
Re: exhaust manifold boltz?
while im not quite sure what you mean by 'boltz' but the exhaust manifold bolts on mine came right off with a little muscle pushing the wrench, im by no means extremely buff so if i can get em loose im sure anyone else can
wicked.. does anyone else with a 305 v8 accually have a gasket in between the manifold and the engine block? or was there never one there?
i took a look at mine today and it seems there was a bolt missing so i went and got a new one and it made the engine barly run.. my muffler is crushed so i believe that is what is going it.. i will disconnect it tommorrow to see if that is what is causing the weird idle... thanks for the help
