Fan switch delete?
Fan switch delete?
Anyone out there removed the coolant fan switch and just hardwired their fans? I know you can hardwire them, but I am unsure as to if not plugging in the fan switch will throw a code or cause the computer to runn funny-Thanks in advance-
Re: Fan switch delete?
too much trouble and work, just use what u have wiring and all, and just ground the relays with a switch to turno them on or off when the car is on.
alot of info on www.thirdgen.org
about wiring fans to switched.
third gen cars have two things that turn on the cooling fan, the cooling fan switch located on the passenger side of the car and the a/c system. i cut off my cooling fan switch wire and was just gonna hook it up to a toggle and ground it to turn it on but its too much of a pain IMO. so now until i get a fan that meets my temp range needs i just use the max a/c on low to turn on the fans if i get too hot, i did the a/c delete so it doesn't affect me any. get a switch that turns on at a lower temp range so you don't have to worry about all that turn on/off junk.
carguyshu
01-22-2017 11:19 AM
