Fuel Injector Installation-
Re: Fuel Injector Installation-
Yea, that sounds good to me. The injector harnesses only go on one way if i remember right. I know on mine, getting the TPI setup off the motor sucked. Hope it all goes smooth.
put some vaseline on the seals so you don't F them up when you put them in, and then they should just pop into place and make sure they are straight out, and put the rails on....pretty simple...
07-04-2005 05:00 PM
