Fuel injector lbs
Fuel injector lbs
Can someone tell me how to tell the differance between certain injectors?? I have a '89 Camaro RS that had the engine changed in it, it was a 305 TBI and now it has a 350, I want to make sure that the person who changed the engine also changed the injectors (I've heard it will lack performance if they weren't changed to the proper lb injectors).
Well, somebody's a little grumpy. But he's also right. Gotta run the numbers.
Also, TBI injectors will handle MUCH more fuel pressure than they typically run at stock (12-14 PSI). Some people simply juice up the fuel pressure (doubling it or more in some cases) to achieve virtually the same thing as putting on larger injectors.
<font face="Verdana, Arial" size="2">Originally posted by 87DJP2001:
Pull one of your FI and get a part number and mfg off of it. We are not mind reader who csn say what FI you have by the short and
non-informative Post.</font>
1989 Camaro RS Convertable
350 ci Throttle Body Injection
(no mods yet, mostly stock except the 305 was removed and replaced with a 350)
Suggestions very much welcome!
1996 Pontiac Firebird 3.8L v6 (Stock), Black
1986 Chevrolet Camaro v6 2.8L (Stock)
<font face="Verdana, Arial" size="2">Originally posted by Damon:
</font>
</font>
Viper
I would guess, the so called 350 with the TBI
set up would have the old 305 TBI with the same fuel injector. On TPI systems you would change to 22# FI @ 45psi fuel pressure
and this is not your case, a guess again. Not
too many TBI's on a 350 which is a poor combination. My opinion.
1987 Black Camaro IROC-Z (original owner)Replaced LB9 @ 86100 miles.
New 350 Crate Engine
Balanced & Blueprinted
World Prod SR 67cc Heads 9.6:1 C.R.
Cam 454lift,216dur@50,110ls
TPI Induction(from 305)Hi-Flow Wells MAF.
22# Fuel Injectors
AFPR @45 psi & Gage
SLP Intake Runners
Fastchip Stage 2 chip
K&N Filters and Airfoil
Hotchkis STB
SLP 1 3/4 Headers
3" CATCO Catalytic conv.
SLP 3" Catback Exhaust
700R4 Auto
SLP Torque Converter(2400 stall)
1LE Aluminum Dr Shaft
Spohn Perf. rear LCA's & Panhard Bar
1989 B-W 9 bolt Limited slip 2:77 Rear
Four wheel Disc Brakes
10.5 F & 11.655 PBR R
17x8.5 ATI 5 Razze Wheels
245/45/ZR17 Tires
New DYNO RESULTS:
215 RWHP & 287 RWTQ
276 HP & 368#/ft at FLYWHEEL with all Emission controls installed.
13.74 @ 96.781
A DAILY DRIVER
22# Fuel Injectors
AFPR @45 psi & Gage
SLP Intake Runners
Hotchkis STB
SLP 1 3/4 Headers
700R4 Auto
245/45/ZR17 Tires
New DYNO RESULTS:
215 RWHP & 287 RWTQ
13.74 @ 96.781
A DAILY DRIVER
Viper
</font>
Viper
</font>
<font face="Verdana, Arial" size="2">Originally posted by ViperXx:
Yah my opinion too, not my idea to put it back on Personally Im getting ready to purchased a complete TPI setup, harness, injectors, manifolds, all, going to cost me about $450 though..
</font>
</font>
92BLKL98
'92 Black Z28 Hardtop w/Harwood 2" cowl ind. hood Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods, removed cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
07-04-2005 05:00 PM
