Fuel pump change is a PITA
Just what that says changing the fuel pump the right way is a PAIN IN THE A$$.
My husband & Brother in law have been working on it all moring long.
My car broke down 2 blocks from the house & man everthing went down hill after that.
Originally posted by TheGreatJ
Gotta be electrical....mechanical pumps are cake. 4 bolts, 2 lines, and pull it off the block. The in-tank electrical pumps.....now those are a PITA.
Originally posted by krazzycowgirl
bleed the brakes.
bleed the brakes.
I've done several FI pumps. First time it took 3 hours. I can do one in under 2 now. Never had to disconnect ANY part of the brake system.
Originally posted by Marc 85Z28
No wonder it was a PITA. They do have a clue what they're doing
They took the REAR end off & the only way to do that is to disconnect the brake lines.
Yeah it is a pain. It's not necessary to take the rear off, but like you said, if they did, then obviously they will have to bleed the brakes. I don't know if taking the time to take the rear off would be of a benefit.
Like Marc said, some can do it in 2 hours (with experience) others probably around 4 with the rear on the car.
No matter what They had to drop the rear end because of the way that everything is set up in the car. They had no other choice unless they cut the body of the car (on the inside of the car) Which I would have screamed at.
10-31-2016 11:09 AM
07-04-2005 05:00 PM
