ground effects removal on a 92
After you remove all the screws on top of the ground effects and the underside ones how do you get them off the body on a 92 RS. I thought they were the same as my Z but i guess not.
There is also a sheetmetal nut that holds them on in the rear quarter panel. You'll have to remove the lower back seat and carpet, as well as some foam-like sound padding to get to it with an 11mm socket. Best I remember, the nut should be about 6" in front of the rear wheel well.
Be sure to tape your extensions and sockets together cause dropping them in that part of the car is a PITA.
Damn, i remember the 90 and pre ground effects were the fiberglass ones with the screws behind the emblems but ive never dealt with the aero scoop type ground effects. So damn i have to take all the carpet out and ****? I just got done cleaning the carpet and putting all my wires down for my amp n ****. Thanks for the help i guess ill just wait till summer to do the work.
10-31-2016 11:09 AM
sodak86
05-24-2015 03:54 PM
Caps94ZODG
22
07-30-2002 08:45 AM
