Has anyone fixed a code 43?
I had this issue before and my motor went bad not too far in the future, make sure it is the sensor and you aren't getting any rod knock. I would also check your compression as well.
Since you are going to get a bunch of coolant out of the Knock Sensor hole, you might as well do a coolant flush as well.
Good luck!
Good luck!
