hatch mortor
hatch mortor
When i hit the hatch switch the hatch starts to come up but if you don't get thier in time the mortor will pull it back down. I have the mortor ajustment all the way up i think i need to go down if i am correct. hope you can help.
shane
shane
A freind of mine has the same prob with his T/A. what it probably is, is the hatch struts are just starting to go. they dont have the umph to hold it up just that little bit, so the sensor reads that the hatch is ready to be closed. the struts will hold it up at full extension, it's just that little bit when the struts are just starting to push.
REDNECKISBOSS
05-20-2015 10:03 PM
01-13-2015 09:52 PM
sleeperZ96BT
01-06-2003 07:44 PM
