Hatch Pull Down
Hatch Pull Down
Having trouble with the trunk pull down. I have checked the fuse it is good, swapped out the relay with a new one. Still no luck. I opened the trunk last night and the pull down did not come up. The trunk opened and now I can not get it to lock. Can not get the pull down to come up so that I can lock the trunk.
im going through the EXACT same situation right now w/ my 86 IROC. the plastic gear that rotates to raise and lower the pull down is probably stripped. u just gotta get a new one.
this is the gear im talking about.
pic of my old one: http://www.cardomain.com/member_page...05_39_full.jpg
pic of my NEW one: http://www.cardomain.com/member_page...05_57_full.jpg
you can find wat u need here: http://www.fbodymotorsports.com/HatchParts
the pull down gear/screw is only $10...u just need to get White Lithium grease.
Do you happen to know where the contact is that makes the pull down device go up and down? I have been working with it and for now for some reason it is working. I am thinking that I might need to clean the contact.
Download the info and repair info from www.top-downsolutions.com. Everything you need to know about repairing your hatch and the parts needed.
