heater core
heater core help
ok i need a new heater core, i already have it accessible but, the plastic cover the core (the one with the clips) is making it hard for me 2 get it in right, do i put in the core first then do the plasic cover? or the other way around?
I know I installed it bolted together. It slide right in, only problem was that the in/out tubes were not bent correctly so I shoved the core pretty hard and finally it seated perfectly and bolted in good. I bent the vac. assisted doors tho so now my controls don't work. Everything blows at the floor.
ducttape1975
07-10-2015 06:29 PM
