HELP!!!! car won't start!
I just got this 86 IROC with a 305 TPI for insanely cheap but it doen't start up. The last owner was a hack and he messed with alot of things on the car. The car cranks but won't actually start. All it does is turn and pop. I have sufficient fuel pressure(have a guage and an adjustable regulator), and the injectors are getting power(tried an injector tester). I thought it was ignition (the last owner had disconnected the distributer) so I've replaced the cap, rotors and coil as well as the spark plugs. I am getting spark to the plugs. Its not a plugged exhaust, the cat back and cat are not installed. I have fuel, spark, and air to the best of my knowledge. The timing chain can't be broken, since the ignition works and engine cranks. I haven't tried a compression test yet, i'll get to that soon.
I'm out of ideas why this car won't start. Can anyone please help out!!!!!
Yah, the guy that had my car before the guys I bought it from messed with the ignition a lot too. He couldn't get it to start, but it ended up that he just didn't have the right firing order on the plugs.
12-04-2014 11:56 AM
lbrowne
11-13-2011 04:25 PM
