horn and cigarette lighter not working..fuse?
it's an 89 formula, 305 tpi speed. i suspect it's a fuse but the car has no owners manual so i don't know which one it might be. anyone have pics of a fusebox or any suggestions?
hmmm..... the horn and cig lighter aren't labeled specifically, is there any thing else thets not working ? i also went out and checked on my 87 and noticed the fuse block didn't have the horn or cig lighter specifically labled either
ok, i fugured it out: seems like the steering wheel was disassembled by the guy i just bought it from and the red wire that feeds into the hole on the wheel is disconnected. when i placed the wire back into the hole and the brass surface inside the wheel touched the wire, the horn worked. now all i have to figure out is how to get the wire and the brass surface inside the wheel to be permanantly bonded.
as for the cig lighter, i pulled it put and realized it was not connected to it's wire either. seems like i'll be ripping the console apart to straighten that out.
thanks for the suggestions.
brothaslide
01-09-2016 12:11 PM
NewsBot
09-14-2015 08:50 AM
eanhl2004
04-04-2015 12:01 PM
