horrible gas mileage
Old 09-20-2002, 11:57 AM
  #16
RickS's Avatar
i think its the fuel pump, its makin unusual noises wile running
RickS is offline
Old 09-20-2002, 03:29 PM
  #17
IROC5.7TPI's Avatar
Rick,
My suggestion would be to check the VSS (vehicle speed sensor) with a scan tool and make sure that it reads correctly at speed. This will affect fuel mileage as well.
Another thing you may want to check- the back brakes may be sticking due to parking brake use. I have seen this happen before where they drag and cause sh!tty gas mileage.
If all else fails install a TPI'd V8
IROC5.7TPI is offline
Old 09-20-2002, 05:54 PM
  #18
90rocz's Avatar
You can also tell the ratio of your gears by marking a line on the drive shaft and a line on the tire. (where you can see both)
Spin the tire 1(one) revolution, and count how many revolutions the drive shaft makes.
Example: 3 and 3/4 turns= 3.73's
3 and 1/4 turns= 3.23's and so on...
90rocz is offline
speedracer1280
09-08-2015 06:12 AM
08-24-2015 06:41 AM
Rittmeister
08-07-2015 01:13 AM
CARiD
07-07-2015 08:19 AM
Campbellb48
07-05-2015 06:31 PM
Quick Reply: horrible gas mileage
