horsepower on a 89 gta 5.7 a4 duel cat g92
#16
Re: dyno happy with what happened
Originally posted by Irocdriver89
well i went to the dyno yesterday and it showed 273 horsepower to the fly with 360 torque which was pretty good for my setup the guy said. i added the air foil,hooker headers,borla catback ,true duel piping,1.6 roller rockers,bbk throttkle ram air hood with ram air setup, i did cheat a little i ran a fan in front of my car to cool the air oh thanks for the suggestion i did not buy the hypertech chip i had one burned by a guy who worked at a speed shop.
#17
hpandtq
240 rwhp and 323 rwtrq, which is not that hard to get out of a tpi 350 setup, but i'm still trying to beat an 00 ss camaro with k/n and flowmasters. so i know i will need adlease 290 horsepower to the rear well to pull on him in the quarter mile.
#18
I would say you have more than 273hp at the crank, 240rwhp through an auto works out closer to 300hp at the crank using around 18% drivetrain loss which seems to be about the accepted rate for an auto around here... Did the dyno guys come up with the 273hp number? Even if you use 15% loss you'd be looking at 232 rwhp for 273 crank... I've yet to hear too many people suggest an auto setup only sucks out 15% or less to the rears...
#19
don't know
15 percent drive train loss is low, but that was the numbers i pulled i am looking for another dyno around here so i can make them numbers for sure because even when i ran them they wanted me to run it again because they said the numbers did not seem right. But they were going to charge me the same to do it again if those same numbers came up.
#20
#21
Re: don't know
