How can I stay at WOT in 4th gear??
Old 09-03-2002, 12:32 AM
  #16
aziroc's Avatar
Post
if i rememebr corectly, u need a 4th gear kickdown something or another. basically what is happening is, in a 700r4 u can only use 4th gear if u r out cruizing *low RPMS* but if u go past like 3/4 *or is it 1/4 throttle* throttle, it kicks down into 3rd *i hated this casue it top out then engine *my old 355* at 130'ish. i beleive www.summitracing.com or www.jegs.com sells these 4th gear kick down eliminators fairly cheap. i also know www.tpis.com sells them *thats where i got mine.. so i know they have it.
1986 IROC-Z
406 SBC TPI
399.6 rwhp 436.1 rwtq
*damn injectors running lean*
aziroc is offline
Old 09-03-2002, 10:52 AM
  #17
jayman350's Avatar
Post
I have the b&m valve that was listed earlier, its a piece of cake to install. just drop the pan, undo like 3 bolts, slip out the old valve and put the new one in. if you're in there you might as well change the filter cause you'll have to take it out of the way to get to the bolts.
The valve works great on the highway, although it definately takes some getting used to when you think it should downshift to pass someone and it doesn't unless you really lay into it. I love being able to cruise around in 4th gear and not worry about the stupid thing downshifting all the time.
I've been told numerous times that you shouldn't have to shift into OD at the track, what gears are you running? You should be hitting the top of 3rd at the very end of the 1/4 (in a perfect world w/ a perfectly matched setup)
Jay
black 85 Z28 - waiting on a new paint job, then she'll be real purty
blue 85 Z28- not running right now, but that should be fixed soon (I hope)
87 Chevy S10 Blazer- 2.8 liters of pure fury
Jay's Website
yahoo im: wildcat856
AIM: Jayman85Z
Homer no function beer well without
check out GMPerformance.org
jayman350 is offline
Old 09-04-2002, 06:51 PM
  #18
Pro Built Automatics's Avatar
Post
First, "do not" disconnect the TV cable, as this can/will destroy your transmission. Second, modify the TV plunger sleeve by blocking the 4-3 part throttle passages with 2 small Allen screws (17 cents each). This will give you 3-4 WOT shifts at the predetermined governor shift points. It will also eliminate the 4-3 down shift once above about 75 mph.
Pro Built Automatics is offline
Old 09-04-2002, 07:14 PM
  #19
smallwood's Avatar
Post
Do not disconnect the TV cable. It helps determine fluid pressure in the trans. More throttle = more pressure. Or something like that.
Little red light on the highway; big green light on the speedway, hey,hey, hey!
2002 Formula, GMMG cat back /1983 Z28-sold
smallwood is offline
Old 09-06-2002, 07:18 PM
  #20
cwalsh
Guest
Posts: n/a
Cool
Part number is a #8673948. Saving reciepts is great!!!
1989 IROC Camaro L98,A4
Flowmaster American Thunder cat-back, punched out cat, fully modified MAF, gutted air box, air foil, TB bypass, TransGo shift kit, Black GTA wheels,Quarter Stick. Weld in SFCs, '91-'92 Ground effects & spoiler, VFN 4" cowl hood, Spohn LCA's, Spohn LCA relocation kit, MAC panhard bar, BMR strut tower brace, MAC Headers, LT4 Hot Cam 3.73 9-bolt.
http://home.swbell.net/cwalsh76/index.html http://www.custommotorsinc.com
1/4 mile 14.71@92.1MPH
60 Ft 2.03
With 3.27 gears
Old 09-06-2002, 10:59 PM
  #21
newby's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by cwalsh:
</font>
Cool, thanks. I'll have to see what I can do when I actually get some money Being broke sucks.
[This message has been edited by newby (edited September 07, 2002).]
newby is offline
Old 09-08-2002, 11:33 PM
  #22
cwalsh
Guest
Posts: n/a
Smile
was only about $13
60 Ft 2.03
With 3.27 gears
10-31-2016 11:09 AM
jayblev95
01-20-2015 01:30 PM
blac94Z
01-12-2015 05:44 PM
07-04-2005 05:00 PM
IgorT.455/406
06-04-2003 03:32 AM
Quick Reply: How can I stay at WOT in 4th gear??
