How do I tell what compression I have?
Im wondering what compression I have..Im suppose to have 10.1 ...how can I tell?
does it have to do with the pistons and heads? My pistons are Keith Black .30over flat tops.
I dont have a compression tester thingy...and I dont feel like buying one.
I just need to know for sure what I have so when I get a cam and heads I know what I have..
can someone help me out?
Re: How do I tell what compression I have?
Here is how you calculate it:
http://www.carcraft.com/techarticles/982/
Not really....unless you buy the pistons with the kit and it tells you what cc heads to run to get a desired compression.
That's the true way to get your true compression instead of just an estimation from the piston and head cc. B/c gasket thicken, block decking, etc all plays a role in compression.
well crap!..then Im screwed.......I kinda wanna know for sure what I have...cause if I order a cam and tell them that I have 10.1 and dont then the cam will be wrong....so now I dont know what to do...Im suppose to have 10.1 according to the guy I got it from..but for some reason I dont think so.
surreybrad
09-29-2015 09:00 PM
