How do you descreen a MAF?
You have to cut them with a pair of cutters. I wouldnt do it though. If you have to do it just cut the rear screen out and leave the front one in.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Descreening your MAF will net you some more airflow. But you are playing with fire when you do this. If ANYTHING large enough to break the filament in the MAF gets into the intake tract, you have just bought yourself another MAF. They are not cheap. Do the real only if you want to do anything but don't do what I did and do both. I am just waiting for the day when somthing gets sucked in there and BOOM.... No more MAF.
Take off just the rear screen to be safe. It'll definately flow more air. I used needle nosed piers and tore it off carefully.
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Denny Villemure
www.denny.cz28.com
As long as you run a good arfilter with a good seal, then you will not have to worry about debris taking out the sensor wire.
The screens cause alot of turbulance and should be removed. TPIS said it netted another 48cfm by taking them out.
I removed mine about 40,000 miles ago and the MAF still works fine.
