how fast am i going?
my 84z speedo only goes to 85mph,but when i open her up on the highway how fast will this stock 84z go,and how much horse is this 305 5.0 puttin out. it feels pretty damm fast?
Unfortunatly they are pritty damn slow, you will see once you get use to the car and u get are *** kicked my an lt1/ls1. I think the fastist that car would go would be 120mph MAX. I beleive, i had a friend that had and 84z that was a dog. Anways hopefully you didnt get his old car
89' red Iroc-z
386 stroker
Mini ram, 58mm tb
30#lbs,255 high flow fuel pump
slp cam, 1.6rr
edelbrock performer heads p+p 2.02 1.60
Hooker super comps, Mufflex 4' exhaust
Ford 9' 4.11 gears, detroit locker, 31 spline
Full suspension
B&M mega shifter,2800 stall
baer rear brakes,line lock
converted to speed density
Ed Wright dyno tuned
89' red Iroc-z
LT-1, 4L60E
free mods,chip,no cat, flowmaster
full suspension
89' red Iroc-z
386 stroker
Mini ram, 58mm tb
slp cam, 1.6rr
Full suspension
89' red Iroc-z
LT-1, 4L60E
full suspension
There is an equation that you can use to figure out how fast your car will go. Go to www.thirdgen.org and look in the "Equations" section seen on the left side of the page. All you need is your gear ratio, tire diameter, and RPM.
I topped mine out at 137, thats on a radar gun too. My uncle works for the highway department and he had access to one for some odd reason.
1983 Z-28
305 LU5 V8(Cross-fire Injection)
Radical Cam
Limited Slip Differential w/
3.23 Gears
700R4
T-Tops
Pics-- http://www14.brinkster.com/ctrwsz28/
1983 Z-28
Radical Cam
3.23 Gears
700R4
T-Tops
