how much hp gain with extractors?
how much hp gain with extractors/headers?
im in Australia, got an 85 iroc. Ive got a quote on custom built extractors, larger throttle body, larger port injectors, removal of the air pump and a couple of other small things.
What sort of gains am i looking at?
And can you recommend any other small things to do to the engine? Just looking to do small stuff and build it up.
its a 5.0L 305, everything is stock except for a worked exhaust.
thx for any info.
thx for any info.
Re: how much hp gain with extractors?
you probably won't see too too big of a difference, but i'm sure you'll definately feel a little more in the seat of your pants...the big thing is your stock TPI intake...it doesn't do any good to just throw a big TB on front of a stock TPI, because your only gonna flow as good as your weakest point, and that would be your intake...the headers should help out quite a bit tho. i would maybe look into porting your intake out maybe, there is some nice pieces of info on thirdgen.org's site for this kind of stuff...but with bigger injectors, bigger TB, full exhaust and smog delete and everything your going to need a custom chip burnt for sure. just something to think about. But go to thirdgen.org board and you can find a lot of free mods that will help to free up a little bit of HP, but a little bit adds up...
yeah the chev expert in my local area said that he can put the car on the dyno and reprogram the chip after i have done everything.
Will removing the cat gain some hp? Because its not legal to have a cat over here.
Unless you're planning on doing some MAJOR modding to that little 305, getting a bigger throttle body is completely pointless. Do a search on thirdgen.org, there are at least a hundred threads documenting this. If anything, get an adjustable fuel pressure regulator. If i remember correctly, the stock pressure for 85's was very, very low. An adjustable regulator can also make your stock injectors keep up with what you're planning on doing and then some.
Originally Posted by 85_305
^There isn't a fuel-pressure regulator for carbs right? I dont think so... not positive though.
The original poster has TPI,85_305 has a carb.
You only need a regulator on a carb if your fuel pump is pushing out too much PSI and you needs to bring it down some...or in my case,about 30 PSI
no....we need to know what intake the author of the thread has....i'm guessin he has a TPI, because bigger throttle body isn't what you hear very often on a top mounted TB motor...
After hearing him describing headers as extractors, i'm not entirely positive he's not calling his carb a throttle body.
CARiD
09-30-2015 05:44 AM
colts0455
09-02-2015 12:41 PM
NewsBot
08-03-2015 02:40 PM
